Took apart a dead Energizer lithium 9v battery
PhotonWrangler
In a handbasket
I had a completely discharged Eveready lithium 9v battery so I decided to open it up to see what was inside.
It was surprisingly easy to get it open. The metal foil wrap peels off to reveal a battery holder with three exposed, unlabeled CR14250 (1/2-AA sized) cells that I believe are Lithium-Manganese. Each cell is rated at 3.0 volts. They're obviously wired in series. There is no protection circuitry, just three cells in a holder.
From what I've read, Lithium-Maganese is a fairly safe chemistry with no highly reactive or toxic compounds in them. One of their big selling points is a wide operating temperature range of -40F to +140F. Apparently this battery chemistry is used in a lot of medical and safety equipment.
I'll post pics once I get an issue straightened out.
The regular old alkaline 9 volt has 6 little cells in her.
Yes that was interesting the first time I opened one up. I think the first 9v battery that I disassembled contained 6 generic looking rectangular packages and a later one contained 6 AAAA cells. I was also surprised to find 4 C cells inside a 6v lantern battery. Later on I found a lantern battery adapter with user replaceable C cells.
If they are less than 1/2AA you could use 2 in series to have a 6V AA sized cell. Isn't that what CR123s are made of or maybe coin cells.
Hmm, yes I could. They are the same diameter.
You would mod a 1AA light to LED with an appropriate dropping resistor inline perhaps. My early LED mods to incans used 3 or 4 cell hosts and resistor. I took incan flashlight bulbs that burned out and broke the glass and gutted them and soldered 5mm LEDs in the 4 or 4 LEDs with a resistor in the base of the bulb soldered one leg to the top of the bulb. You could even use 4 of these in a 2AA light to get 12V. Not sure that they batteries can manage a high current load though.
Discovered this a while back as well and made a note of it JIC. Allthough they're not rechargeable these 14250 sized primaries fit my DQG Slim (1/2) AA!
