Torchlab Head empty?
yellow
Baden.at
Anyone has an idea where to get a torchlab head for the moddoolar bodys, without any light engine?
I have already asked directly at oveready's, but there seems no option for this.
With the adapter, the size advantage to standard 6P hosts is gone, so ...
The Moddoolar head is not available without internals since there´s no dropin inside it but LEDs & electronics are built into it (afaik, I didn´t touch one yet).
Since you mentioned the size advantage over the P60 heads I wonder what you have in mind? Without the adapter it fits moddoolar bodies only anyway. And if you don´t use moddoolar bodies you´d have to use an adapter anyway.....
Eric
in mind were full moddoolar body and head + homemade light assembly.
... just that tad smaller and shorter and less edges, to make it "better pocketable" than a modded 6P
+ the very cool looking knurling
relatively easy mod, as the inner part will be 90 degrees flat, not V-shaped.
and I could use some driver I want, the available heads are in no way what I want.
(then there is the price)
((and when someone using several individualized oveready hosts does not consider the price worthy, then this price must really be too high))
:rolleyes:
