Toshiba yellow 10mm 23,000 mcd LED ?
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by KenB:
Has anyone tried this one?<HR></BLOCKQUOTE>
Where did you see that LED?
www.hosfelt.com
they also have a 10mm white for $5.99
<HR></BLOCKQUOTE>
I sure can't recommend that
particular LED, cos I bought one and it's output was SUPER disappointing...
I might have a bag of these... let's see...
Let's see... Hosfelt # 25-342...yup that's the one.
The beam is square in shape, very narrow with a darker spot in the center.
Taking picture... click!
Downloading...renaming...moving...cropping...uploading...
In this picture, the LED was fired at the target from 3 FEET, so you can see its beam is very narrow. That is one reason why its candela rating is so high.
At 30mA drive current, my meter says 23.2 foot-candles in intensity. For this measurement, the LED was fired at the sensor (the diamond-shaped thing in the picture) from 12" away.
Hope this helps.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by videocal:
<HR></BLOCKQUOTE>
I can't recommend their 10mm white either.
I've got a bag of those things, and I can't give those fu$&^@%#ers away!
Thanks Craig, it does not look to impressive...gee...you really do have a museum their...umm you wouldn`t happen to have the white 10 mm would you?
Thanks Craig, it does not look to impressive...gee...you really do have a museum their...umm you wouldn`t happen to have the white 10 mm would you?<HR></BLOCKQUOTE>
Yeah... I've got a whole bag of those things.
I'll go look for them. I think they got buried in the you-know-what, but I have a good idea of where to start looking.
Thats ok Craig, I`ll take your word for it...probably narrow with that square shape...thanks Craig and Doug
I couldn't find the bag, but I had my original pair of evaluation specimens in a plastic case.
Picture was deliberately underexposed to try and capture the distinctly bluish center.
In reality, the beam consists of an elliptical central hot zone, bright cyan in color, surrounded by a much weaker, white coma. It looks like a comet without its tail.
Measured 10.6 foot-candles from the distinctly bright cyan central beam area.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by telephony:
<HR></BLOCKQUOTE>
I can't show you a picture of mine yet, but it measures only 9.5 footcandles..
Btw-Craig, do you know whether Nichia or Toshiba makes that 10mm wht.?
<HR></BLOCKQUOTE>
How do you measure yours?
Do you fire the LED directly into the sensor from a foot away, or some other way?
<HR></BLOCKQUOTE>
I believe Toyoda Gosei made that one, but I cannot say with absolute, 100% certainty.
I can tell you that Toshiba isn't (or wasn't) in the white LED racket when these things were made, and the design of the internal leadframe is not Nichia.
How many foot candles does...say a Photon with new batts show from 1 foot away Craig or Doug?
How many foot candles does...say a Photon with new batts show from 1 foot away Craig or Doug?<HR></BLOCKQUOTE>
Let's find out... it starts at about 27 foot-candles, and quickly drops like a bomb, even though you can't observe the difference with the eye.
It quickly sinks to about 20 foot-candles, then falls much more slowly after that.
Doug, does your`s show about the same?...Craig, how many does the Arclight show?
Doug, does your`s show about the same?...Craig, how many does the Arclight show?<HR></BLOCKQUOTE>
about 18.4, and it stays there instead of sinking.
This is about like a Photon after 1 minute.
Thanks Craig, I wish CMG would up the step-up in the infinity to the Photon level...that would be ideal.
