triple p7 in 4d mag help
derek750
:thinking::thinking::thinking::thinking::thinking::thinking::thinking::thinking:
Im trying to build a triple p7 in a 4D mag with up to 4 18650 lions
Can i direct drive?
If I do need driver which one and how do I wire it??
If I have the back of the p7 touching the heat sink, can i wire it in series because if i wire everything backwards to make the frame positive it will be wired in parallel right??? or is there some adhesive that transmits heat well but does not conduct electricity?
THANK YOU :twothumbs
Newb
You will not be able to direct drive 3 P7.
Your best bet is to get Der Wichtels kit. He sell with a couple of drivers and gives you instructions on how to set it up.
I just built one last week as well. The LEDs can be mounted with Arctic Alumina Epoxy. It transfers heat but is not conductive.
Der Wichtels heat sink is also annodized which electrically insulates the led + / -.
I will second the DerWichtel products they sound like exactly what you need, they will suit your project well. He has great prices and the product is made very well.
