SWM
- Joined
- Dec 18, 2018
- Messages
- 26
TrustFire T70 Tactical Flashlight, Hunting Light, 18650 cell, 2300 Lumens, with Battery Charger, Magnetic Light Holder and Remote Switch
Hunting Kit
🔦 HIGH LUMENS FLASHLIGHT: powered by 2pcs 18650 3400mAh rechargeable batteries, delivering a brightness level from 130 lumens to 2300 lumens. Perfect gifts for your loved ones, family, friends, teachers, and neighbors.
🔦 HOW TO OPERATE: power on/off the light only by tailcap switch, both tail and side switch can be used to cycle through modes from Turbo (default setting) → High → Medium
🔦 ACTIVATE STROBE MODE: press and hold the side switch for 1.5 seconds to enter into strobe mode, the blink refrequency will change every 2 seconds
🔦 WHAT YOU GET: 1*TrustFire T70 Tactical Flashlight, 2*18650 3400mAh batteries, 1*TR016 USB Battery Charger, 1*Lanyard,1*GM03 Flashlight Mount,1*Remote Pressure Switch, 1*User Manual.
DESCRIPTIONThe T70 is a dual-switch tactical flashlight that delivers a maximum output of 2,300 lumens and a beam distance of 1,080 meters. The flashlight is powered by 2pcs 18650 3400mAh batteries (included). It adopts 2 versatile switches of tail switch and side switch. The T70 is desigend to be powered on from tail switch and change modes from the side switch. With high performance and easy operation, also with a bezel diameter of 64mm, the T70 is a perfect illumination tool for hunting or search and rescue.OUTPUT:
View More on TrustFire UK Store, Click Here
TrustFire
Hunting Kit
- Turbo: 2300 lumens / 100minutes
- High: 600lumens / 11.7hours
- Medium: 150lumens / 68hours
- Turbo: 2300lumens
- Light Source: Cree XHP35 HI cool white
- Max. Throw: 1000m / 1094yards
- Length: 8.31in/211mm
- Head Diameter: 2.52in/64mm
- Body Diameter: 1in/25.4mm
- Body Material: Aluminum Alloy
- Battery Source: Included 18650 batteries
- Waterproof: IPX8
TrustFire
