trying to find these screws
Going to be a bit hard - the 5mx.8mmx6mm button heads should be do-able, but getting them with the glue patch is going to be, shall we say, almost impossible - then again, just get some "blue loctite"
If you can deal with Button head, or pan head, and slot/phillips - MSC has them in stock (mscdirect.com)
Ah - there we go - McMaster-Carr ( www.mcmaster.com ) has what you want except for the glue patch - order today, you'll have it tomorrow - order some loctite - the screws are part number 91239A220
BTW - for things like nuts/bolts/screws etc - you are almost always better off buying in bulk
McMaster wants $10.66 for 100, or less than 11 cents each - The hobby place wants $3.99 for 5 - or basically 80 cents each - almost 8 times the price
Whenever I'm ordering from an industrial supply house, and I need to pad the order to make a minimum or a qty break, I order fasteners. I have a drawer system - 3 ftx3ft - FILLED with Nuts/Machine Screws/Washers/Lockwashers etc, and I still end up with "I can't believe I don't have XXX"
why dont You just get similar sized ones and one tube of blue loctite threadlocker?
Comes in handy very often.
well I went to some hardware stores after work and the last one that i went to had the exact type i needed but they were twice as long, any how they guy noitced that when he threaded a nut onto the one he had it was almost exactly the same length that i needed if i cut off it off above the nut, so i got a few and went home, put one in a vice with the nut on it, used the dremel to cut off the extra above the nut the backed the nut off to "clean" the threads. The guy was very helpful, he even offered to cut em down for me if i wanted him to, but i said "no thanks. i' do it with the dremel"
here is the one cut down with a origonal one on the right
http://www.putfile.com/pic.php?img=5145238
close up of the hub, fit is perfect
http://www.putfile.com/pic.php?img=5145590
overall
http://www.putfile.com/pic.php?img=5145236
Also i do have locktite which i will use, i did not even think to check these wheels as i have never had them off, the passenger side was replaced after i hit a railing and blew both right side wheels off and snapped the upper and lower control arm as well as a bent shock tower, due to a 4 wheel drift.
Thanks everyone for your help.!🙂
