This is primarily aimed at SureFire lights and the protected rechargeables for sale at Lighthound.
Here is what I think I know...I welcome any comments.
Rechargeable batteries that will fit a SureFire without it being bored.
17500, 14500 (apx legnth of 1 1/2 CR123 batteries)
17670, 14670 (apx legnth of 2 CR123 batteries)
Then we have the 18mm diameter batteries which are 18500 (apx legnth of 1 1/2 CR123 batteries), and 18650 (apx legnth of 2 CR123 batteries). A Typical SureFire body would have to be bored out for these to fit.
All the batteries have a peak voltage of 4.2V, but underload usually run at 3.7V.
The mAh go as follows...
17500 - 1100mAh
17670 - 1600mAh
18500 - 1300mAh
18650 - 2200mAh
14500 - 750mAh
14670 - 1100mAh
So having owned none of these batteries I assume that 17670 are the most desirable for non bored 2 and 4 cell SureFires, and the 17500 are the most desirable for the 3 cell SureFires. And for the bored out versions you would use 18650 for the 2 and 4 cell lights and 18500 for teh 3 cell lights.
I am guessing that since the normal CR123 battery is 16mm diameter, then the 17500, 17670, 14500, and 14670 are either 16mm or 17mm. I am assuming that a 17mm battery will fit in most SureFires (except maybe E bodies) since the normal CR123's actually fit a little loose.
So what I don't know (assuming the above is correct) is where the 14500 and 14670 come into play? They have low mAh, and would seem to discharge quickly in applications like flashlights. Any comments?
So please make me smarter by correcting what I have gotten wrong, and adding what I missed. Hopefully this will be a good thread for new guys like myself trying to get smart on rechargeables.
17500 - 1100mAh
17670 - 1600mAh
18500 - 1300mAh
18650 - 2200mAh
14500 - 750mAh
14670 - 1100mAh
