gcbryan
I've read everything I could find but after wading through all the terminology, examples, math, etc...I still have this question.
Perhaps someone has a good example to help me visual this. I've read all about one candle one foot from a one square foot piece of paper but I still don't quite have my answer.
Specifically, I have a Proton Pro (fairly new so I think it's a little different than older ones as far as max output). I'm guessing max output is around 100 lumens. I think older ones were around 80 lumens and newer ones around 100 lumens or so (I'm not sure about this).
It's the low end I want to understand both for the main white led and for the smaller red led. I'm posting in this forum because it really isn't about the Proton Pro. I'm just using that as a reference point since I have one.
At night with no lights on in the house I used the bathroom shower as a test area. I couldn't see at all when the Proton Pro was off. I ramped the main white led to it's lowest setting and I could see very well. I can walk around a dark house with no problem as well.
It's supposed to have a very low low mode but I don't know if it's 5 lumens, 2 lumens or less than one lumen. What reference can I use to determine this?
Also, when I ramp the red led to it's lowest level I can't see details very well. I can tell the light is on but have to move the light around to really make out my surrounding even when it's a white shower wall a few feet in front of me. If it was totally dark in the house (rarely is) it would be hard to walk around at this output level unless my eyes were totally dark adapted. What reference can I use to determine what this very minimal output level is?
My guess from the reading I've done is that perhaps the white led at the lowest level is 2 lumens and the red is 1/2 lumen.
How can I come to a more accurate educated guess (not using light meters or any equipment)?
Someone with more knowledge than I must know what lumen level the red led in the Proton must have to be at given my description of what I could see (human lower threshold) and someone must also have an educated guess as to what the white led must be outputting given the source (Proton Pro) and my description of what I can see.
Anyone?
Thanks.
Anyone?
Thanks.
