I need to turn-down an existing NX-05 to make it smaller in both diameter and length. I have a Dremel, but am unsure with adapter would be best suited for the cleanest "cut" possible. Should I use the sandpaper wheel, grinding stone wheel, etc?
Nascar I read a post recently that spoke of sawing the Nxo5 to length and repolishing with progressive grits of sand paper.That is the only detail I recall, Sounds like a lot of work. good luck /ubbthreads/images/graemlins/popcorn.gif
I can't remember the thread either, but I'm pretty sure it was the Fraen that was used.
Basically, the face of optic was sanded on a belt sander until the desired height was reached. Then it was finished with two very flat mill files. Finally polished. It looked fantastic.
