Turquoise AAA?
Status
Not open for further replies.
Osm3um
Tacoma, WA
How can I tell what color my arc aaa is? I think I ordered a turquoise but that was a while back...
As I recall there were at least a couple in this same color range.
Thanks,
Bob
Duhhhh! I misunderstood the post...never mind...move on to next post.
BTW, my ARC AAA is "turquoise" as compared to a known Photon Turquoise and also a known green one.
The ARC AAA was available in two colors that are "sort of" similar to turquoise, blue and green. If you have ARCs in all three of those colors in one place it's easy to tell them apart /ubbthreads/images/graemlins/grin.gif
The blue Arcs I have seen put out a "royal blue" light, no green in the beam. Not likely to be mistaken for turquoise.
The green ARCs I have seen put out an "emerald green" light, leaning neither toward the blue nor yellow side of green. If your ARC has much blue tint to the beam, it is probably not a green.
Turquoise is blue/green of course. If you can't decide if your ARC is green or turquoise, find a Photon or similar LED light with a known turquoise or green LED and compare.
And then there were some in cyan, 'tho mine is pretty green.
If it helps, mine does cause a bit of a "black light" effect. You know like flourescence on certain items.
Thanks,
Bob
"shameless plug mode on"
Mine is available on BST right now.
"shameless plug mode off"
Colored ARCs come up for sale every week or so. If you are patient you can find just about anything on BST.
Status
