First post on here but been reading all your posts with envy for a long time.
MY BUILD:
2 * MCE Cool white LED's on round 20mm pcb (when it arrives from cutters)
1 * Plain tight 26.5mm lens
1* Frosted medium 26.5mm lens
housing is going to be copper tubing with a moddified p3 heatsink stuck on top to fit inside some old lights (sounds messy but will post pics once complete)
Plan is to run each MC-E as 2s2p resulting in 6.4v 700ma on low (7v 1.4A high (if can find driver at which can go from 700ma-1.4A))
now my sticking point....:shakehead
I want to be able to either dim both lights or switch one off when not in use (parrel is best for this right?). to do this I will need 2 drivers one for each MC-E right?? Was thinking of using a bflex as its thermal sensors would come in handy.
WHATS the expert opion on driving 2 MC-E and what combination would you use?
power will come from any number of combinations of 2.5A nimh AA's.
(current rig is 20w spot + 30w flood halogens overvolted at 13.2v + 33batteries hence me changing to LED's :thumbsup
MY BUILD:
