Two general LED questions.
  • Thread starter Thread starter ELJ
  • Start date Start date
E
ELJ
Guest
Hi, this is my first post here. I have done some digging and have found no answers to these questions, but I apologize if the solutions are obvious or have been discussed before.
1) Why is nobody developing very large LEDs (70mm+) for things like automotive headlights and house lighting? It seems like everyone is concentrating on LED arrays instead of increasing the size of the "bulb" itself. I imagine that heat is a big concern, but it seems like larger units could be more easily focused with reflectors like traditional 9004 (etc) vehicle headlights while still retaining a big advantage in efficiency and wavelength considerations.
2) Are there any Internet resources that explain in detail how LEDs are constructed?
Ill give this one a try. LED size is based on the size of the dice, or the crystal. this is very small. A 1 watt is about 1mm x 1mm. The larger you make them there is problems with heat dissipation, and just the process of growing them itself...
As far as a site explainig how they are grown/constructed..
I don't have anything.
Jeff
ELJ
The answer to your second question, will also answer your first. What searches have you made on the topic so far? If you draw a zero, I'll point you to a few. You just have to use that search function.
GregR
[ QUOTE ]
ELJ said:
1) Why is nobody developing very large LEDs (70mm+) for things like automotive headlights and house lighting? ...it seems like larger units could be more easily focused with reflectors like traditional 9004 (etc) vehicle headlights while still retaining a big advantage in efficiency and wavelength considerations.
[/ QUOTE ]
I believe (though I'm not a lighting designer) that in general, smaller light sources are actually more easily focused.
Simple lamp reflectors are variations on the parabola, with a light source at the focus point. A real lamp filament isn't a true point source, of course, which can mess up the light projection. But with a linear filament, for example, you can at least align the filament with the axis of the reflector, so the variation from a point source is at least one-dimensional, and in a relatively easily dealt-with dimension. LED emitters are planar in shape, and a large one would probably be much more difficult to focus. Consider the dearth of florescent headlight designs; florescents are far more efficient than incandescents, but their low intensity (and thus the large area needed to emit suitable amounts of light) would make them too hard to focus.
I also believe you'll find that the efficiency and wavelength advantages of LEDs may have been... exaggerated.
LEDs are rugged and long-lasting, and they don't lose efficiency when run at reduced power, the way incandescents do. That makes them great for flashlights, which need to survive a few hard knocks and deal with a variable power supply as their batteries fade. But they're only about as efficient as halogen bulbs for producing white light.
Colored light is a different story. Monochromatic LEDs are usually a lot more efficient than an incandescent bulb with a power-sapping colored filter. So you do see LEDs used in traffic lights, where they can shave big bucks from a municipal electric bill, and in taillights and turn-signals, where their fast startup time can actually be a safety advantage.
I'm not sure exactly what you mean by the wavelength advantages, but a halogen bulb is about as good as it gets in terms of emitting the whole visible spectrum. White LEDs, like florescent bulbs, sodium street lamps, and HID headlights, only emit a few colors, selected to fool your eye into thinking you're seeing white light. It's not always completely successful. Vibrant red colors in particular look washed-out and dull under "white" LED light, which is really only narrow spike of blue and a few colors near yellow, with very little actual red.
[ QUOTE ]
Lagged2Death said:
I believe (though I'm not a lighting designer) that in general, smaller light sources are actually more easily focused. ...
[/ QUOTE ]
My understanding is that it is easier to do the calculations the closer the source is to a theoretical point source. With some sources their size blocks the efficient use of simple reflectors. This is why smaller diameter florescent are preferred over their larger cousins.
George
