SilverFox
The SureFire U2 has several battery options. I decided to check a few out.
At level 6 the U2 draws around 1.3 amps, so testing at 1.5 amps is a bit high, but close.
Please note the difference in the Pila 168A and the 168S. It makes a lot of sense to go with the 168A, if it will fit in your application. The larger size adds a lot of capacity.
The SureFire 123’s ended up at 93 degrees F, the 3 volt R123’s were at 90, and the Pila batteries were at 82 degrees at the end of the test.
The 3V R123’s are the first generation from Jon Burly. I believe he has some improved versions at this time. Please understand that these are a work in progress. It would appear that they are better suited to lower current applications at this time.
Ah = Amp Hours
Wh = Watt Hours
M = Minutes
Pila 168A = Fat Pila’s
Pila 168S = Pila’s that fit the SureFire L4 and other SureFire lights
SureFire 123 = Standard SureFire 123’s
1st Gen 3V R123 = First Generation of the 3 V (not the 4.2 volt) rechargeable 123’s from JS Burly’s.
Edit: I have added the results from a bare cell LG 18650 rated at 2.4 Ah. If your are considering using bare Li-Ion cells, make sure you have the proper charger and take care not to over discharge during use.
Two SF123’s and two 3V R123’s were connected in series for their respective tests.
Here is the data:
Tom
Ah = Amp Hours
Wh = Watt Hours
M = Minutes
Here is the data:
Tom
