UltraStinger Ni-CD Batt Pack....
Dukester
Washington State
Anybody know the mA ratting for this batt stick. I need to set up my ICE Charger to condition the pack.
Thanks,
Dave
The original sticks are rated at 1800 mAh. I do not think SL has upgraded from this in the last couple of years, even though there are much higher capacity Sub C cells commonly available.
If you have an original SL battery, look very closely. They had the capacity stamped in very small size in one place.
Mark
Mark
Thanks for your reply. Yep, you are correct, it is indeed 1.8a. However, when I went to set up my ICE I am not getting a good connection on the neg end of the stick. This truly an stupid proprietary design by Streamlight that has bugged the hell out of me during the past several years. I just tried to scrap away some of the casing to see if I could get to the bare cell but no luck!:confused:
I got it... I had to shave around the shrink wrap in order to pluck off the end casing to get to the bare cell. It is now cycling in my Charger...
DAve
