<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by mad_scientist:
1. Is there a space inside the unit for carrying a spare bulb?
2. Does the construction of the light allow for the focus tweaking?
3. Currently, UltraStinger is not compatible with a fast charger, but a new model that is to be released in 2002 will allow that. Does that mean that they will be changing the battery, or the charger itself?
4. How waterproof is it?
5. Is it possible to attach a landyard?
6. Is it possible to recharge the battery separately from the unit?
7. How useful is it as an impact weapon?
8. Is there a comprehensive review of the UltraStinger available?
Thankyouverymuch.<HR></BLOCKQUOTE>
1)No
2) The focus is completely adjustable, and has a nice tight spot, as well as flood beam.
3) It will be a change to the charger, not the battery pack.
4)It's not dive rated, but is O ring sealed,
and either waterproof, or very, very water resistant. You could use in in heavy rain, for example ( I have, BTW).
5) there is no provision for a laynard (ie. lanyard hole, etc.) If you want to attach a lanyard, it can be done with heavy velcro, and a few other things. there is a thread about this in the past month or so.
6)Not with the factory charger, although you could fairly easily build a charger for the battery pack, if you are handy with hardware, and have another charger.
7) It's relaively lightweight, compared to the Magcharger, for example. You could do some damage to someone if you hit them right,
but it doesn't have the mass for a good impact, with every hit. it was designed to be much ligher in weight to previous Streamlight police type rechargeables.
8) yes, but you'll have to hunt it down. Do a search on the Ultrastinger, and you will doubtless find a link to a review. This light has been extensively discussed here on CPF, if you wish to look at past posts, you can find lots of information, as well.
I have 2 of them, and they get a lot of use. I built extra battery packs using relatively inexpensive sub C nicads, and NimH cells. This is a substantial improvement in light output and weight to the Magcharger, and previous Streamlight rechargeables. It has a lightly textured reflector, that give a very even spot, with no annoying rings and dark spots, but still manages a very good tight spot, as well as a very good flood beam.
I predict you will like it, if you get one.
