I just received a Trustfire TR-J18 that has 7 Cree XML T6's. I threw three Nitecore NL183 2300mAh 18650's charged to 4.2 volts in it and it seemed a bit dim for the specs on the light. I compared the beam to my single XML T6 Ultrafire 502b and they were just about the same brightness with the TR-J18 having a slight edge and spill advantage. I then checked tailcap current. The Trustfire TR-J18 ran at only .85 Amps and the 502B ran at 2.3 Amps. Cleaned all the contacts and checked battery voltage again and got the same results.
Is there something I can do to fix this or should I return it?
