mrheosuper
- Joined
- May 22, 2016
- Messages
- 55
I am not satisfied with my current C8 anymore, so i'm planning to give it some power
First, of course led emiter, i want to change my xm l2 to something more powerful, probably xhp50/70 or triple xp-l hl
I don't what is more suitable, i don't care about flood or tight beam, i care about lumen
http://www.kaidomain.com/p/S023979....-6V-Light-Emitter-with-20mm-x-2mm-Copper-Base
http://www.kaidomain.com/p/S025036....-Mode-Driver-Circuit-Board-for-Cree-XHP-MT-G2
This is the combo i gonna use, will it give me over 2000 lumen?, if i change to xhp 70 will it even be nearly 3000 lumen(of course the same driver)
Second: the diameter of my driver is quite small, it's 17mm driver, so the above driver i think it's not suitable( above is 20mm)
There is a ring outside my current driver, i will remove it, will the driver fit into my host?
(My flashlight is being borrowed by my dad, i can't measure it now)
Third, about the switch,
http://www.kaidomain.com/p/S023885....mm-H-LED-Flashlight-Clicky-Switch-Black-5-pcs
I gonna use this switch, will it work perfectly with my mod?
Thks for reading to the end, and pls give me some advice
Ps: How many lumen do you think this flashlight can reach, i want to push it to the limit, and i guess xhp 70 is the limit
