Capo_au
Hi all
My question is this:
If I was to modify an UltraFire WF-138 charger so that each charging channel was connected to two Protected UltraFire 18650 batteries in parallel, would this have any major drawbacks?
After doing bit of reading in to how the charger performs over at this post I would expect a charge time to be around 4-5 hours, which doesnt bother me.
However my main concern is that even if I used the two identical batteries from an equally discharged stating point that over the course of a charge, or repeated charges, they would become uneven. Would this be the case?
If it works I intend to repackage the chargers internals into a new housing with a 4 core cable connecting from the housing to a 4 cell (2cell's per channel) pack. The goal being a sealed separate battery pack that doesn't require the removal of the cells for charging.
I'm trying to get that end result on the cheap, so if you have any alternatives that are equally cost effective I'm all ears.
This is the first of what I hope will be many posts on this forum. So thanks in advance for any advice and with a bit of luck I might be able to return the favor one day. :)
-Capo
-Capo
