RedForest UK
- Joined
- Nov 28, 2009
- Messages
- 1,365
So, since my last two OTF lumen tables: (1 – here and here and 2 – here) I not only have more lights to test, but have also changed my testing set-up. It seems that the placement of the lights and lux meter, which was an acknowledged issue for V1, was still causing an unecessarily significant bias in V2, dependent upon beam profile.
I have tried a few different positions and now feel that I have ‘fixed’ this bias for a more reliable set of readings. Having done that, I spent a good deal of yesterday testing almost all of the lights that I had to hand. The following table shows my results.
One thing to note is that, due to the repositioning of the lights relative to the lux meter, my lux readings and conversion factor (32) were much lower and higher respectively. This means less accuracy at lower readings, as the lowest possible increment was 3.2 lumens. In light of this I have had to omit a few lights lowest modes, and I would also advise caution in accepting any sub 10 lumen readings as particularly accurate (although they should still be accurate to within 1.5 either side).
Also, here is the link to the table on imgur: http://imgur.com/17zvmUL just in case the image posted here is too large for the CPF rules.
Anyway, I hope you find them useful and/or interesting :)
