I'm looking for a relatively compact and lightweight light to use for two main things: for flying a small plane in the bush - needs ability for adjustable beam (or a very wide beam with a hot center) for checking the plane at night and also navigating in woods in case of emergency landing. Also need red light choice to use in the cockpit and not affect night vision. Would like a relatively small light and lightweight light as I plan to use it for backpacking too. For camping, I would like a light that can have a long enough throw and enough brightness to see a long way but adjustable to be able to us in a tent to read. Thanks for any help!
This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
Up to $200.
3) Format:
I want a flashlight (hand held/self contained).
4) Size:
____SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____90-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____I don't care.
____I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s higher end flashlights).
15) Water resistance
____IPX7 (Waterproof to 1 meter/30min)
16) Storage conditions
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
Up to $200.
3) Format:
4) Size:
6) Manufacturer:
____I don't care.
