Nice work ! I see you both made lens mod (thanks for mako lens info ! ) ...I assume that rkt diver uses original house with doomed lens.
I wish have that dives like Dashrynn ..btw what music group is in video ?
@DocEd ..I think that advantage that camera is that is very mobile , not heavy and small and independant. I think that these advantages should be preserved too.
Maybe could be good to put some small canister behind camera made from handheld torch like : ( I'll do that hoply in close future .. but suggest for DIY )
1. buy small backup with right head like :
GS35 LED Mini (maintitle on page is little confused )
http://www.fwt-schulz.com/lampen/index.php?a=569&lang=eng
2. than I take ''replacement parts '' 2 caps like
http://www.fwt-schulz.com/lampen/index.php?a=518&lang=eng
One cap will go on front of battery holder which made small canister and other cap should go on back of backup head ( they fit together due to same size threads which are M30x1 ( I made Cu heatsinks for them) .
That short backup could hold triple AAA in series , normal bacup can hold inside triple C size battery
It is direct driven led over resistor (with P4) and direct with MC-E
Backup head is not OK because inside is Cree MC-E which made ''windows'' effect, but led could be easy replaced if set heatsink and led in freezer over night (inside thin plastic bag ) to broke arctic silver glue which holds led on its place. Than replace original led with some right led (XML, clouster for some triple kit on star PCB? )
like
http://www.lux-rc.com/view.php?p=content/products/light_engines/3UP/XPGH51
TIR optics should be removed or not depends on desired beam ( front glass is mineral )
Next step is to wire with cable over some proper glands battery cap with lamphead cap.
I have tought to put those both (2pcs) battery pack behind camera and put lamphead on some small plastic holders in size of battery canister which could be hidden under camera and that extend them if needed from right and left side .
I think that could have small system with minimum money ( ok in euros is tahat alot of money cca 350€) but some cheap replacement from DE might work too.
I just focus on these backups because I have them and mod them. Sorry for big pics but can't resize them from direct link
Packhorse also made some small light from ultrafire bacup which shuld be much cheaper as that one but same construction .
