VIOLET LASERMODULES
B@rt
Land of Tulips and Philips
Just got a mail from Roithner about a <font color="purple"> VIOLET </font> lasermodule... /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/cool.gif
technical features:
lasing wavelength: 405 nm +/- 15 nm
laser pulse power: 50 mW
pulse length: 30 ns
pulse repetition rate: 1, 10, 100 kHz, adjustable
beam divergence: < 2 mrad
focus of laser beam adjustable
signal out: laser pulse synchronization, BNC connector
compact size of laser head: 116 x 34.5 mm
compact size of pulse driver: 43.5 x 56.5 x 100 mm³
main on/off switch, ON control LED
supply voltage: 220 VAC
laser diode current adjustable
special, limited one year warranty
$2.047.- ... /ubbthreads/images/graemlins/ooo.gif /ubbthreads/images/graemlins/icon23.gif
Nichia had violet laser diodes a couple of years ago, but they were just that: bare laser diodes. No optics, no driver electronics (PSU), no nothing.
I'm guessing that Roithner's laser modules are using Nichia's violet diode lasers.
It won't be long now (a year, maybe two) before we start seeing BLUE directly-injected laser modules. None of those funky crystals, high-powered IR diode lasers, or other horse puckey. Just like red pointers, only a heck of a lot more expen$ive. /ubbthreads/images/graemlins/icon15.gif
A bare blue laser diode (just by itself, no PSU or optics) cost around $5,000.00 and lasts only 500 hours.
/ubbthreads/images/graemlins/eek.gif /ubbthreads/images/graemlins/eek.gif /ubbthreads/images/graemlins/eek.gif
Hmmmmmm ... 405nM? That would cause quite a few things to flouresce as it's right on the edge of long UV. Could actually be an interesting toy/tool. /ubbthreads/images/graemlins/smile.gif
The million dollar question is can it make a organic dyes go super radiant like my simple and cheap, but quite effective, nitrogen laser. I can get any color of the rainbow to come out of it and for a lot less than 2 grand.
The next generation of DVD players will use blue lasers so expect the cost of blue laser diodes to drop through the floor.
Rothrandir -
OK. Enough with the violet faced shocked look. I've accused you of being the multi-millionaire owner of Roithner B4. You aren't fooling me a bit. You claim to be what? A sophomore? Sure. I believe that. You better start stupiding up you posts if you want to pull this off. If you want help in stupiding up a post, I'm yer boy. Not sure? I said stupiding didn't I? /ubbthreads/images/graemlins/grin.gif
mastershake -
Wow. More please. Wow.
Bart -
As always, a nueron activating subject. Very cool. Thanks. /ubbthreads/images/graemlins/thumbsup.gif
[ QUOTE ]
[/ QUOTE ]
If the laser really lases around 405nm, the beam would appear to be a slightly bluish violet to the eye, not too unlike the surface of a lit fluorescent "blacklight" tube that you might find in a fluorescent Derma-Spec, "money detector", or cat urine detector light. The laser would appear more purplish and less bluish than common 405nm LEDs, because the broadband emission found in all NUV LEDs would not be present.
Most objects that fluoresce under blue and violet light would go apes*** when exposed to the beam from this laser.
I get email from Roithner Lasertechnik every now and again, but didn't get this one.
I dunno. I cain't really member. Um, we wuz just bustin' into a Sundie clay jug-oh-happiness. Yawanna a snort?
Gimme a minut...OK I cut the cork with that fancy bleau flashlight ya sent me. It's a purdy flashlight. I just wish it wouldn't play all my CDs at the same time when I shine it at them. But I gotta tell ya the Bee Gees, ABBA 'n Barry White harmonize real good.
Thanx, buddy.
Well, that's something else added to the "To buy when I win the Lottery list" then! That list is getting VERY long now;
Delorean DMC-12, MaxaBeam, X990 and about 5 million other things that I won't waste time writing this second...
I want one of those purple lasers too, but it's also priced a bit out of my range. And I want a Maxabeam too. And I want one of those electric wheelchairs that goes up & down the stairs, so I'm not stuck here when the elevator poops out. And I want... oh the hell with it. My wants list would probably take up the whole thread.
And yes, some of them are flashlights. Like I need some more of them. /ubbthreads/images/graemlins/grin.gif
