fireofenergy
- Joined
- Nov 11, 2009
- Messages
- 15
Hi,
Just wondering what kind of transistor or FET to use for controlling the input current to 4 XML's in series from a 12.8v battery. I assume that 2A is too much for a potentiometer, so want to connect a potentiometer to the base (or gate) of the transistor (or FET) where, in my limited understanding, a small current controls the much larger current of about 2A. I hear that they drop about 0.7v, so enough voltage should be present from 4 LiFePO4's (which are safe li-ion type of battery) in series to drive each XML at about 3v which, should be about 1.1A at full power, which I know is nowhere close to max rating for the XML, but is good enough for the light I want to make.
My problem is trying to figure out WHICH transistor or FET is the best for this setup as there are so many different kinds to choose from...
Thanks
Thanks
