Packhorse
Check out the new Ultrafire W100.
Takes a single 18650.
Well I finished this one.
I went with a R2 XR-E, Ahorton aspheric lens and a 3x AMC 7135 driver.
I was supposed to be a 2 mode 100% and 10% driver but turns out to have a slow stobe too. Sucks big time.
On the bright side I really like the size and the combo of Li Ion XR-E and AMC driver makes it a very efficient light. It also means it will dim down at the end of the charge instead of shutting off.
Yes. But it will dim down first and give you plenty of warning. 30 min minimum but probably 1 hour +That's a nice size. If the cells are protected it will still just shut off at a certain point...right?
For sure.I think an XP-G driven at 1.5 A would be interesting. That's starting to get in to primary light output if used with a constant current driver with 100% and 50% modes to extend time if needed. You could do a long dive on that before recharging. The small size would allow for hands free mounting.
Due to the wider angle of light dispersion of a XP-G (125deg ve XR-E of 90deg) most of the extra lumen ( if not all and then some) is lost before it hits the aspheric.Do the XP-G's not do well with aspherics? I know there is less benefit over a reflector as far as efficiency but a reflector has spill and an aspheric doesn't so if you didn't want spill but did want a bigger hotspot than a XR-E provides could you use an aspheric with an XP-G?
What would be interesting to test is a de domed XP-G.
How is the light lost in a sealed cylinder?
