lumen aeternum
- Joined
- Sep 29, 2012
- Messages
- 935
Looking for a light that I can program to turn on in STROBE mode from the tail cap -- and will go to STROBE even if already turned on via a different switch. Prefer rechargeable & small enough to put in a belt pouch, but if we're making a list might as well include them all.
Would really like a slide switch or thumb wheel with tactile clicks so I can count to the mode I want (this switch sets only). A secondary switch for a non-STROBE mode would be nice. A "Hidden" mode is useless. Some lights have clicky head caps, but they seem to have more than 3 or 4 modes, which might be a PIA to count through and might get switched while the light is being carried or rolling around in a car.
Lights that do not have a physical indication of their current mode are undesirable; and pretty useless if carried in a vehicle where they might be used by different people.
I read a thread (which I have lost track of) where a policeman from Amsterdam (?) said he went to a manufacturer and special ordered one of their models to default to STROBE for his police force. Wish I could get one of those.
EDIT: It was GrizzlyB in
http://www.candlepowerforums.com/vb...an-T20C-v-Fenix-TK21-v-Olight-M20SX&p=3795682
"Sunwayman T20C, but had the tailswitch and UI changed"
Here are what I have found; none are exactly what i want.
SureFire R1 Lawman
Head Switch: High, Medium, Low, Off
Tail Switch: High and Strobe
Strobe (Tail Switch Only)
With three consecutive presses or twists, the 750 lumen strobe is activated.
3 CLICKS IS A LOT OF FINE MOTOR COORDINATION REQUIRED AT A TIME WHEN YOU MAY BE MOVING FAST TO AVOID BEING RUSHED & ACCESSING ANOTHER TOOL WITH YOUR OTHER HAND. TUELLER DRILL !!!
ProTac® HL HIGH LUMEN TACTICAL LIGHT
Ten-Tap™ Programming – Choice of three user selectable programs:
1.) high/strobe/low
2.) high only
3.) low/high
3 light output levels:
High – 16,000 candela peak beam intensity, 600 Lumens, 1.25 hours runtime
Low – 800 candela peak beam intensity, 33 Lumens, 18 hours runtime
Strobe - 2.5 hours runtime
Uses two 3V CR123A lithium batteries
To change to the next program, tap the switch rapidly 9 times (within 0.4 seconds per tap) and hold it down the 10th time. Continue holding the switch until the light turns off (approximately 1 second), then release the switch.
Available programs are Hi-Strobe-Lo (Factory Default), Hi Only or Lo-Hi.
SO YOU HAVE TO REMEMBER WHAT PROGRAM YOU ARE ALREADY IN, AND THE SEQUENCE OF THE PROGRAMS... I CAN SEE THAT IT WILL REQUIRE CYCLING THRU ALL OF THEM A COUPLE TIMES BEFORE BEING SURE THAT YOU ARE STOPPING ON THE ONE YOU WANT. AND STROBE IS STILL NOT THE TURN-ON MODE.
FENIX RC-10
Cree XP-G (R5) LED, using the specific built-in rechargeable Li-ion battery,
it maximizes up to a wonderful 380 lumen output.
RC10 offers 4 brightness levels and an instant strobe.
charged by an AC charger or a car charger.
TAIL SWITCH, WITH A SIDE SWITCH FOR MODE SETTING (???) -- THE FENIX SITE DOES NOT GIVE THE DETAILS FOR HOW TO SET THE MODES ETC
NITECORE MT40 Multi-Task LED Flashlight
860 Lumens with CREE XM-L U2 LED
Uses 2 x 18650
With the head loosened about a half a turn, the light goes into the user defined mode. Switching the light on and off cycles through the different outputs: High, Medium, Low, SOS, and Strobe. The last output level you select (after leaving the light off for more than 2 seconds) will remain when the light is turned on. At any time, tightening the head will put the light back into Turbo mode.
The MT40 can be powered by 2 x 18650 batteries or 4 x CR123 batteries and can run for up to twenty four hours.
SureFire R1 Lawman
- Output: 750 lumens high, 150 lumens medium, 15 lumens low
- Intensity: 16,000 candela
- Runtime: 1h 45min high, 5h 15min medium, 37h low
- Battery: Lithium-Ion Rechargeable Battery or 2 x 123A
- Length: 8.1″
1.) high/strobe/low
2.) high only
3.) low/high
FENIX RC-10
Uses 2 x 18650
- Turbo: 860 lumens (1.5 hours)
- High: 530 lumens (3.5 hours)
- Mid: 280 lumens (7.5 hours)
- Low: 100 lumens (24 hours)
