Warm white Lumiled Flashlight
Adam PAtrick
Hello I'm new to this forum and to flashlights in general to be honest.
I currently collect holograms, which need a warm white lumiled LXML-PWW1-0060 led to work well. Currently I use a bulky lamp which has these warm white led's in the head, though what I would love is a flashlight which had the warm white led in.
So i was wondering if anyone knew of a flashlight that uses these warm white led's LXML-PWW1-0060.
Thanks for reading,
Adam
I thought of an old luxeon ... less than 1/3 of the output of an actual led at the same power consumed, much more heat production, ...
but its even worse: a rebel.
There is a reason this one has not been in use for long time ... construction fault
dont think You will find anything with that led now. (and if You find, its not worth the money, as it will be very old and cheapest production clone lights)
1st: Your holos will work with any led, the tint does not make a difference.
2nd: the most recent led, that is almost similar (but much more efficient) to a rebel, is a cree XP-G.
Search for any light that features a "neutral", or "warm white", one and it will work.
This rebel is shown to have 2500-3500 Kelvin tint. Any actual "warm white" will fit into this very wide range.
Even most "neutral" ones are close (those are brighter at same power)
Does the original setup, or the light You use now, work with a reflector or optic, or totally without focusing device?
What kind of power source do You want?
Without knowing these anwers still some options:
4Sevens Quark lights, Zebralight models (with or without reflector possible) ...
