been looking high and low for a warm white p60 drop in, cant find ...
does one exists? will love to own one though .....
I don't have the Dereelight dropin.I do have the m30wf and it is damn nice.I did notice that dereelight is overdriving the led at 1.2amps. Cree's data sheet specs the q3 5a emitter at 700mah. http://www.cree.com/products/pdf/XLamp7090XR-E.pdf.How does the dereelight drop in compare to the malkoff in brightness. Are they comprable or is one significantly brighter? Thanks for any help.
all seems to had sold out somehow ,,,,,
any in stock?:crazy:
According to MrGman's integrating sphere readings, the Malkoff M60W is about 160-170 lumens (more at start up) while the Dereelight 3sm Q3 5A is only 146 lumens, which means that the M60W is a bit brighter.
I'm very happy with my DX Q2-5A module. Its an excellent value. I use it with RCR123 cells.Is the DX 12501 drop-in still a decent unit (with the warm tint)?
I just received a 6p light with the stock incandescent drop-in.
Also, being new, can you tell me if I could use the 3.7v 123A rechareable batteries with this drop in? I assume the stock light can only handle the primaries.
Thanks
