Weapon light standards
I'd say it might matter if its a mission critical situation, as in, if the light fails, is it dangerous, or, is it just inconvenient.
I prefer to use stuff that's at least intended for weapon use, like my Klarus XT11 has a dual sprung cell chamber...the cell is cushioned fore/aft...and it has a multi-mode pressure switch...which they made to use in a weaponized environment, heck, its about the ONLY pressure switch that also lets you change brightness, or even strobe, let alone the normal on/off most switches are limited too.
That light can take some serious abuse.
We have seen even AK47/AR15 type recoil shake apart a DX type light....the head can fall right off (Almost no thread overlap on tube sections on the el cheapo lights..). Of course, dropping one of those el cheapos on the floor will wreck them too.
So, if the light failing is not going to cost anything but some acceptable level of inconvenience...I guess anything might work.
If the light failing means someone (Unintended) might get hurt, or the level of inconvenience is not acceptable...then getting something made for weapon use is a better idea.
Even SureFire are not immune. One buddy paid ~ $400 for a SF, had to send it back for repairs 3x, and just gave up on the 4th...he never quite trusted it after all that. He went to Streamlight. Of course, he checked out my Klarus XT11 just last week, and, now he's ditching the Streamlight too, he loves the XT11. He wants MINE. :eek:
He's going to replace his current duty light with one too.
Dual springs are not for recoil per se'
It allows batteries to shift fore and aft and maintain contact. The TZ20 weapon kit is designed to use a18700 battery. The battery is long enough to compress the spring in the tail cap and maintain contact even under recoil.
I have seen some very expensive scopes come apart under the recoil of airsoft because the recoil forces on some of them are opposite standard firearms. The FAL is especially rough on scopes even though it is a very soft recoiling gun
I'm one who picked up one of those cheap lights off ebay. It actually has very bright output. Has a small spring near the head, and a "tube"-ish spring at the tail cap. I don't know if it WILL end up on my AR, but if it does, it is cheap enough that if it fails, I won't cry about it.
True. However, due to circumstances, really can't afford a high priced option. Realistically, the need to have a light on an AR [for me] is rather low, . . . and I can't even begin to imagine a time when I would even get to try it out at night. Just potential "tacticool" ideas that probably won't come to pass.
This light I got, . . . though. . . is pretty nice for its cheap price. Very bright on high [an XM-L] with a close to white output. It was worth what I paid for it, for sure.
