Whether or not Astrolux makes a good flashlight, I decided to get one anyway. Saw a review on FLASHAHOLIC_TV's channel. When I got it, the beam pattern of the LEDs selected [SST40, 5000K] was very poor, IMO. Many rings, artifacts, and not the output of the Acebeam L35 I have.
I found a "problem" with the FT02S. When the light is on, a double click should cause the light to go into "Turbo" mode. But mine did a bright flash, then turned off. I clicked the button, and nothing happened. No amount of clicks did anything. The light on the switch was also out. I unscrewed the tail cap, then screwed it back in, and it worked again....until I tried the same experiment. Light on, double click, flash, then stops working.
I got this light from Banggood [whether I should have or not]. Why? Because I didn't see it on either Amazon or Ebay. Anyway, I started a return/refund process, and Banggood wanted me to take a video of the experience. For some reason, this morning, I put in a different battery than before, to do the test,.......and it worked. I thought to myself, "it's like when taking your car to a mechanic to tell them about a problem, and it doesn't do it".
So, finding it weird, I took that battery out, put the battery I had tested the other night into the flashlight, and sure enough, light on, double click, flash, stops working. I have two of the same batteries and they both do the same. The one I tested this morning hasn't done it yet.
The two batteries that have the issue: Nightcore 18650 3500mAh, 3.6V, 12.6Wh
The battery that doesn't have the issue: Lumintop 18650 2400mAh, 3.6V, 12Wh
What's going on????
What's going on????
