What is an SMD flashlight?
ToneBeamer
Ohio
Hi, I'm new here and just learning about the wonderful new technology with flashlights.
What is an SMD flashlight, and how do they compare with LEDs or an LED emitter?
SMD = Surface Mount Device.
Other electronics uses components with "legs", that goes thru the circuit board.
Nearly all the high-power LEDs used in flashlights today, are SMD's.
I have an eBay seller that says "SMD is brighter than LED."
Is that true?
It's a meaningless statement.
LED is literally Light Emitting Diode, a semiconductor that produces light. An SMD LED is a subset of all LEDs that has a specific type of packaging.
The classic LED package, a small plastic bulb with pins on it, is not able to reach very high power because the heat it generates will fry it. One of the useful characteristics of surface-mount LEDs is that they can be mounted to a metal plate which draws heat away from the emitter, and thus they can sustain higher power (= more light output).
The seller might mean his SMD LED is brighter than some classic package LED he also sells, but the terminology is inaccurate. SirJMD is right that pretty much any high-powered LED flashlight today is already using a SMD component.
If you're looking at specific flashlight models, you'd be better off searching or asking on the forums here about them, if you're trying to understand what the differences are. There's more to it than just the specific emitters in them.
Thanks to both of you for your replies.
I fully understand now what's going on with SMD.
Would that be like a gas station advertising they have unleaded gas? :shakehead
SMD [or SMT] is a classification for certain devices and components that mount on top of [not through] PCBs.
Unless I'm missing something, SMD in a flashlights context either represents a company, or just referencing to the LED or the driver. As long as the flashlight LED is not something that resembles a T1-3/4, its an SMT device...drivers then sure
For an entirely SMT flashlight....dunno, it would resemble something like an SMT joulethief
