simple?
Ask someone else to do it for you. :-)
otherwise, you need to put various currents through the LED and measure the voltage across it. And of course, the LED needs to be mounted on a heatsink.
If you don't have a power supply with an adjustable current limit, then you can add a resistor in series, and just vary the output voltage.
If you don't have two meters (one to measure voltage and one to measure current), you can use a single voltmeter. This does require that you have a resistor in series with the LED. Measure the voltage across the resistor in order to then calculate the current.
To get any more simple, you'd have to be using some batteries instead of a power supply. You would still want to have a series resistor, or multiple values of resistor. To get different currents, either use different resistor values, or let the batteries discharge gradually.
Did I miss an easier method? other than checking the LED's datasheet, of course...
Steve K.
