What range of lumens and run times are we getting now for the latest generation LEDs?
GTSECC
Is it around 50 to 100 lumens and 30 mins to 2 hours run time?
1st: that depends on Your power source!
the general max is some 800 mA to the led, what makes about 200+ Lumen,
(exception is K2 with 1.5 A and thus some more lumen for considerably more power consumed, all my following typing does not deal with that led)
in real a single 18650 can power such a led at full power (around 200 lm) for 2 hours + some mins, lets say: 20.
underpowering them - as Your range covers the nominal - to the measured value of a given output at 350 mA drive --> about 95-100 lm for the latest led, ..., that makes some 6 hours
PS: the value at 350 is measured and therefore realtively granted, the max power is calculated, as far as I understand the datasheets.
I meant to say AAA battery
You'd get about 100lm-120 OTF from 1AAA for about 30-45mins. The Avg AAA nimh is around 800-900mAh to get 100-120lm OTF you're looking at about 600-800mAh at the LED. With some loss in the driver. This is for a single die. The MC-E or P7 could do this with much better runtime.
50lms you're looking at ~1.5 hours. Same logic but less than half the current values.
You're incorrect. AAA Ni-MH has ~850mAh @1,2V. To get 90-100 OTF lumens you must drive R2 at 350mA = 1050mA from battery + driver losses. Boost drivers are not very efficient, 75-80% is very good result. Runtime would be up to 30 minutes with 1200mA current draw.
You're right my numbers were off. I wasn't thinking too clearly and messed up.
Does anyone make a P7 or MC-E AAA light?
makes no sense, especially because this here
is not correct, there is (were) almost no difference at all
+ a quad-die from a single cell is stupid. Even pushes a Li-Ion cell very hard
makes no sense, especially because this here is not correct, there is (were) almost no difference at all
This is where you're wrong. At 350ma to the LED the P7 and MC-E dies would be seeing around 87.5ma per die which is more efficient than a single die seeing 350mA. At 87.5mA per die you're over 100lm/w (IIRC it's close to 120lm/w)where you're around 97-100lm/w with a single die. If you drive the LEDs are around 100mA then the quad die LEDs are close to 150lm/w. Where the single die is still in the 100lm/w range.
It's not always about driving something at it's hardest, sometimes it's about getting the best efficiency.
But yes no one makes a MC-E or P7 powered AAA light because at that size you could just as easily make a AA or 18650 light.
