You are walking on a thin ice with power supply voltage being lower than forward voltage drop for LEDs. Once your supply voltage drops below turn on threshold of your LEDs, you torch will cease to shine.
Now if you decide to increase the size of your battery stack, you will have to calculate resistor value using this formula:
R = (Power supply voltage - LED voltage) / desired current
Power rating of your resistor will have to be AT LEAST:
P = I^2 R
Now let's say you have a battery with 12V output, your LED's will need 7.74V and you want to drive your LEDs at 3 AMPs:
R = (12-7.74) / 3 = 1.42 Ohm resistor
Power rating = 3^2 * 1.42 = 12.78W
Now for comparison, your LEDs power will be (U * I) = 7.74 * 3 = 23.22 W
Now it's up to you to decide if you want to waste 12.78W heating the water around your torch....
