D
**DONOTDELETE**
Guest
Re: Spare battery carriers that I use.
The ASP Time Capsule carries two CR123s, a rubber switch membrane for the ASP Taclite, and a bulb. It contains 2 endcaps: one contains the switch membrane and the other carries the bulb. It can be purchased through the ASP website: http://www.asp-net.com/ProductImages/ASP53024.jpg
It is crafted from aluminum and appears to be the sole product on the market specifically designed to carry CR123 batteries in a container that is water resistant, robust enough to withstand hard usage, and of physical dimensions that can be easily and comfortably carried in a typical garment pocket.
