Chicken Drumstick
More woes with my MagCharger :(
It had been working fine, then one day stopped charging, well the small LED on the cradle stopped coming on.
I've got 2 cradles (one new after it stopped charging) and also got a new power supply as well as a 12v power supply.
The MagLite still works and the battery still has power in it, so I can't see why it would be the battery not accepting a charge. And I've tried all the combo's of cradles and power supplies, so I'm fairly convinced they aren't the issue.
So what else can cause a MagCharger to stop charging?
I notice there's a small diode in the upper contact ring that has a small spring on the end of it, is this likely to be the cause or should I be looking at something else?
Thanks.
Thanks.
