Which charging rate you will choose?
Which Charging mA will you prefer?
  • 1050 mA
    Votes: 8 57.1%
  • 550 mA
    Votes: 6 42.9%
  • Total voters
    14
Sanyo.Eneloop
India
I have a Sony BCG-34HC charger, which is capable of charging AA NiMH at 525mA or 1050mA,I recently bought 4 new Eneloop(1500 cycles ones) and I am worrying that if I charge them at 1050mA they might get killed in short time,is this true?
Assuming the charger has good termination detection, I'd charge at 1050mA. The slight drop in voltage at full charge is more detectable with a faster charge than it is with a slower charge, so it's actually easier for the charger to detect. That's probably an ideal charging rate with a good charger -- although either setting should work fine. Things get a little dicey at 2000mA charge rates. More heat. I'll use that if I need to charge batteries in a big hurry, but my prefered setting is 1000ma for AA and 500 ma for AAA -- basically a two-hour charge.
1000mA is normally better. I still often use the slow (300mA) setting on my old Maha MH-C401FS since I'd rather miss a termination on slow than deal with how hot the cells sometimes get on fast. Eneloops are doing ok on Fast, but a lot of other cells I had problems with.
I usually charge mine at 250mA for AA and AAA, and if I am in a hurry, 1500mA for AA or or 600mA for AAA has never failed me...I have a 1 hour old digital concepts charger, and a rezap RBC883 (which I like a little better...)
