Kill-O-Zap
I would like to drive a 5W LS, preferably even overdrive, with some converter or combination of converters (parallel I suppose) fed by just two NiMH C cells. I don't care if the converter(s) are operating in "regulation" mode or just huffin and puffin trying to meet demand, since the NiMH's themselves will provide as much regulation as I require. However, efficiency is a concern; I'd like to keep it above 75% if possible. I don't mind using multiple converters, and I suspect I'll have to, but...
which converters can do what I want? and how many would I need?
What would a single BB do when faced with a 5W LS (let's say K Vf rank) on <2.4 Vin? What would a MM+ do? Is it safe to try, or would I fry the converter?
If there's no solution, I could use 4@1/2C cells, but they are only 1300mAh vs. 4000+ for the C's, so I'd lose quite a lot of runtime, that's why the contorsions to use just two cells.
Thanks for any suggestions, especially from Wayne /ubbthreads/images/graemlins/grin.gif.
