Which is brighter
Bytes
The Streamlight Luxeon Jr or the Mini-Mag with the Luxeon drop in?
Probably the Streamlight Jr Luxeon because it's easier to design good thermal management from the ground up than it is for a drop-in replacement bulb.
I have both. The Streamlight is way brighter. Great light. I doubt that the run times would be close. Can't have every thing.
SteamLight Jr- I have both. I even tried to hot rod the MAG drop in and fried it (Hey it last for 30 seconds) /ubbthreads/images/graemlins/mecry.gif
NikolaTesla /ubbthreads/images/graemlins/smile.gif
An Arc lamp is the Spark that takes away the Dark--HID Forever!
My Lights LightWar /ubbthreads/images/graemlins/xyxgun.gif
It'll depend on the "drop in." There's quite an assortment out there.
I'll have my Jr in a couple of days, but I'll be very surprised if it's as bright my sandwiches with R2Hs running from 400mA to 900mA+.
I don't really understand what you're saying about my post. I don't know if you consider Wayne's sandwiches a commercial product or not. My post is about them and the heatsinking is adequate.
There are 100s, if not 1000s of them in use by CPFers and problems are rare. If you're running a hot rodded version, then common sense dictates use.
The question was, "Which is brighter?" My answer is the same, it depends on the module. A R2H ranked HD Lux running at 400+mA will be brighter than a P or Q LD running at <400mA. It will take some really **** poor thermal management to screw with that fact.
