Which Warm Parellel High power Led for today?
VidPro
Lost In Space
Your keeping up with all the changes better than i am.
If i wanted a Warm white led item that is parellel 3.6-4V style, was fairly efficent , and extreemely powerfull.
there was Zero need for a tight emitter, or any issue with how the array is laid out, meaning a big flat 1cm array would still be ok.
which one should i get
Can i get a SST90 in Warm or neutral? and who stocks such an item?
Purpose to stuff behind aspheric lens on mag, which has big alum sync, prefer Mounted items on PCB boards.
Right now it houses a MC-E in warm, and has a special diffuser for the led array.
the throw type or emitter pattern is not a problem, for me as it might be for more important stuff. the color though i would want to be nutreal or even warm at the cost of actual lumen numbers.
i cannot find a SST 90 in warm or nutreal at some of the place i would normally buy?
or what kind of single item cree would woop the pants off the mc-e in raw lumens reguardless of the emitter style?
have any links or pointers?
