Why are Diamond Dragons not used more commonly?
easilyled
Middlesex, UK
Just wondered why Osram Diamond Dragons aren't used in flashlights more. (Not golden Dragons which are more common)
From what I understand, they output almost as much as quad-dies like
the SSC-P7 or Cree MCE, but because they are single die leds,
they throw much better and don't have donuts or crosses in the center of the beam.
Therefore I would have thought that they would be the ideal led of choice.
Certainly if you look at the beamshots in this thread (post #8), they look very impressive:-
http://candlepowerforums.com/vb/showthread.php?t=219608
I'd be interested to hear any more more about these relatively unknown emitters.
... was not able to find Voltage ratings ... :thinking:
(thus assuming single-die emitters)
http://www.osram-os.com/_global/pdf/Professional/LED/Productflyer_DiamondDragon.pdf
but with 225 lm @ 1.4 A they seem to need almost the double power than SSC/Cree
(somehow resembling the older K2s, as the nominal drive current is so high)
(PS: how come You mean they produce the same light than full powered quads? is there any documentation?)
.........(PS: how come You mean they produce the same light than full powered quads? is there any documentation?)
I found this link which shows 330-390 lumens output at 1.4A for the group binned as NY (see page 8)
http://catalog.osram-os.com/catalog...=downloadFile&favOid=020000000002b450000200b6
This matches the figures given in this Sales Thread on B/S/T
http://candlepowerforums.com/vb/showthread.php?t=219677
This output certainly seems to be in quad-die territory as far as output is concerned.
For instance MCE K-bin outputs a minimum of 370 lumens at 350ma per die which equates to 1.4A in total
Probably the NY bin is available only in a limited quantity? The lower bins don't look so interesting.
