Hi,
I'm currently trying to install some plant light in my terrarium using 5mm LEDs to get the exact wavelengths needed - plus some white light so it doesn't look like the 70's
So now I just tried to put a circuit of 19 5mm LEDs together to try and see how the plants would react if I went full scale. However I must have done something wrong (btw. I'm far from an electronics expert ) because those white LEDs are definetly not putting out the 11.000 mcd they should. I tested one individually and it is putting out ALOT more light than the ones in the circuit.
The red ones seem very bright, and actually dominate, even though they are fewer and less bright..
Here's the circuit:
Can anyone tell me what's wrong?? I thought that the resistors would make every one of the parallel series have a voltage drop of 12V and hence the current through each should be 20ma.. But as I said I'm far from an expert so I'm not even sure I make sence here
Hope someone can help!
Christian
Edit: Btw. the power supply is regulated, and rated at 500mA
Here's the circuit:
Christian
