On my phone so I'll give a quick reply.
It decreases apparent size of die which increases surface brightness. It also decreases angle that light is emitted by 13°.
In short, it increases throw (can double it or more depending on reflector) , makes the tint warmer and loses a small amount of lumens.
so you mean that if my led angel is 125 and by dedoming it . it will be 125-13 = 112 degree ?
If you do a good job, and don't remove phosphor,
:D
As I posted before, I botched two xmls, carefully slicing off tip then progressively more of the dome. At even just removing the tip of the dome, things got colder and dimmer. I think rememer I testing current, so likely no weird forward voltage shift going on.
No luck with Exacto knives, I wonder if you could dedome one by buring off the dome with the soldering iron tip? Has anyone tried this?
I am still tempted to buy another cheap t6 dropin and butcher it. Does this make me some kind of a serial killer?
Its typically impossible to judge brightness based on wall shots. If the beam is smaller...that's easy enough to tell, and normal for dedomed led. If smaller, it means the lumens are all more concentrated....hence higher lux.Based on the above picture, it looks to me that the domed beam is brighter and bigger. Like my botched jobs, except warmer.
The correct explanation of de-doming form Dr.Jones can be found here. He also mentions common misconceptions of how it works. Many people have wrong ideas about it.
In the end the following things will happen:
- the lux values of a flashlight will almost double
- around 10% less lumens (for Cree LEDs)
- the tint will become warmer, maybe around 1500K less than before
- the hotspot will get smaller
This sounds exactly like my impression as well.
I'll add that the spill and corona shrink as well depending on the type of light...with the impression being that the hot spot was augmented by output that was previously in the spill and corona...so as they are reduced, more lux is available for the hot spot.
The hotspot becomes smaller because the apparent size of the die decreases (the dome magnifies the die).
The lux values only go up because of one thing: the led is more intense than before => its luminance is higher.
The led becomes more intense because light reflected off the surface of the die back into the led can be converted to white light again and emitted at a different angle by the phosphor. Removing the dome means that more light is reflected back and re-used (=> total internal reflection).
This has to do with the refractive index of the phosphor and of the dome. Please read the explanation I linked to in my earlier post.
No question...I meant that the impression, as in, what you see when looking at the beams, in comparison...is that some of the the light that was in the corona and the spill was transferred to the hot spot, not that it was LITERALLY transferred.
:D
Ok, sorry. I misunderstood you :oops:
Another effect in that sense: it makes a flashlight seem more powerful :D :D
