StoneDog
Thanks for going back and confirming. The more I think about this, the more I want to have it checked out and then use it for "normal" situation where magnum loads are not required.
The barrel is clearly stamped with "nickel steel" (or similar). Since you seem to have done more research than me was nickel steel an upgrade, or did they later improve the quality of the nickel steel?
And my apologies to any Georgia duck hunters. All I hear about is deer and turkey hunting. I guess my world is a little too small.
Jon
wylde21 said:Also, to confirm something else stated above, the steel used in these barrels probably should not be used with steel shot (it was not the better quality nickel steel used in later year Model 12s).
Jon
