I have a robotic camera platform, currently using a tiny 12v SLA and PWM on the motors. The problem is one of the motors hits max duty cycle before the rotation speed is satisfactory, while the other motor has tons of headroom. In this application, run time is only seconds at a time, but good current-driving capability at 1A or so is somewhat important--hence the SLA.
I want to increase my voltage so that I can increase the speed of the topped-out motor; I can always throttle back with PWM. I would just buy another 12v SLA and run 24v. However now I'm adding more weight and wiring than desirable just to get more volts. But what else is there? I could use 15+AAs--very expensive for rechargeables, not sure alkalines would have enough balls not to sag the voltage. I could run 5 LiPos...extremely expensive. I could run 7-8 CR123s...at $1 each, it might not be too bad, but where do I get a holder?
Is there a common application for ~24v battery packs that I don't know about? RC cars, maybe?
