Re: Trade for a Tri V?
Yeah, you can use the piston to select the level, which will be remembered by the LE. Then you can just twist the head tight to get that level locked on. You can also repeated twist the head to advance through the levels, and this does work well, as this light's threads are as smooth as any Ti light I have encountered. I think the piston works great. Granted, holding it on reflector for more than a minute with your hand/fingers can be difficult for the weak. Once you train a bit, it is almost like an anti-child measure. :)
Tapping the piston...eh...it is more of a push. It has a much more solid action than a McClicky, if you are not familiar with the PD's.
If you partially twist, moonlight is locked on, indeed (as in photo above).
I have a C-Pack Ti PD McGizmo Mule that we could add in...so you would have both the PD pack and a C pack to switch them up. That starts to approach even, I think.
I also have a complete Moodoo e series Ti 18650 light (including the head) from his recent run I could offer up that is NOT in the photos above. And a Mac Ti Tri EDC Knurly in my hands this week as well. So there are at least two options in addition to the hints above.
Best wishes,
obi
obi
