shao.fu.tzer
Some of you may or may not know this, but I've been working on a reliable infinitely variable QTC forward clicky switch for awhile now. Mostly dreaming and thinking with just a bit of actual tinkering...
Well the good news...
I HAD just officially created a working prototype of the switch which I sought to invent. It would gradually ramp in brightness until clicked on - at which I predict it was only at 60% compression - not giving me full output.
What makes this breakthrough important (to me at least) is that the design is completely battery-independent. It doesn't matter how long of a cell you use because the mechanism and QTC pill are isolated from the negative contact.
I was so excited that I ran around the house showing my fiancee and daughter - I was stoked to say the least... and instead of videotaping it, I decided that I just needed to adjust the size of a few internal parts to get full compression, thus full output when clicked on fully. So I ripped the switch apart and threw the guts into the huge pile of custom machined guts from previous efforts and those unused. Big mistake! My next effort was simply a constant on affair (too much compression) and the one after that (which was actually pretty cool) was a switch that you could twist the tailcap to adjust the compression, then activate the clicky to have it come on in that mode...
Doh! Anyway, I had to share that because I'm really excited right now... I'm close...
Very, very close... Will keep you all updated! Thanks for reading!!!! :D
Shao
Shao
