WTS: TK75vn
Status
Not open for further replies.
Skylumen
TK75vn - Medium Size High Lumen Thrower
Must Read & Agree Before Purchase: Click Here
Photos in post 2
U3 PDTc
Tested with Sony VTC5
3184@ turn on
3158@ 30 sec
1598 high
611 mid
17 low
Throw - 341,000 Lux
SelfBuilt's U3 PDTc Review and Specs: Click Me
A. $200 XML2 6500K Dome on
B. $220 XML2 5000K Dome on
C. $295 U3 PDTc KillerThrow Edition
D. $420 for XHP70/50 NW or CW, LD60vn UI, 3 independent driver for each LED
E. $420 for MTG2 5000K or 4000K, LD60vn UI, 3 independent driver for each LED
User Interface Video: LD60vn Smart UI
+ $5 for "V54" hand engraved
+ $20 if you are outside of USA
+ $10 for Dark Heated Bezel
Email/paypal: [email protected]
Re: WTS: TK75vn KillerThrow Version (XM-L2 Dedome Burn In)
A TK75vn Heavy Engraved Sample - All heavy engraved looks different/unique
Dark Heated Bezel
Dark Heated Bezel
TK75vn50/70 Triple Layer Drivers
Yes, this.
I'm sending you my virginal TK75 in two days, work your magic, magic man.
Matt
Does it still retain the low mode ?
As far as I know...
Burn in is a method to apply heat to the LED in repetition until the forward voltage of the LED increases. The LED will require more voltage to light up but will be able to producess greater brightness at the top end. Thus moonlight could be lost but since the T75vn Lowest mode is far from moonlight this is not affected.
Many including me burn in SST-90s back in the days for similar results.
masha did this with a sst90 by blasting it with like 15+ amps to lower the foward voltage... worked wonders
Put me in for one!
could you do a tn31vn burn in to increase throw even more ?
The first 2-3 mode would be lost if we do burn in too hard in the Tn31vn. So this is not ideal.
Beam Shots is up in post 1
Wow, this is impressive! The spill is still very bright. :twothumbs
Done deal. I'll he sending my new TK75 tomorrow. Can I have TK75vn1?
is it possible to do led burn in for the btu shocker. could you imagine lol
I know the shockervn will throw more but I still like the Tk75vn more...
Just for my understanding, the burn in process is a one time effort and permanent? Or the effect will wear off over time?
sent from phone
Re: WTS: TK75vn KillerThrow Version 4400L (XM-L2 Dedome Burn In)
sent from phone
permanent. Does not wear off.
I realize this probably isn't the conclusion you were expecting but looking at those beam shots I like the TK75vn 5000K Dome On the best. It has the best tint and a good full beam. The KillerThrow is impressive, but it doesn't "kill" the K40vn IMHO, and at long range I find the hot spot of the K40vn is large enough already.
This light is not a K40vn killer in terms of throw. It does kill the K40vn in terms on lumen though. It is it own beast really. I also love the 5000K dome. That one is a Must Have just like this one is. :-)
Status
