X3vn - X10vn Companion
Must Read & Agree Before Purchase: Click Here
- Current boost to 9.6A at Start Up
- 3300 LED lumen at Start Up with Kinoko IMR26650
- Tried a sample with Copper PCB but see did not see a noticeable difference with the eyes (2.5A is just not much to require copper)
- Using stock aluminum PCB to keep costs down due to this reason
- Low-High with last mode memory
- High = Direct Drive
- Light does get got but does take around 5 minutes to do so. Low is great for when the light gets too hot
- Low is abtou 100-150 Lumen
- Tested a couple samples for many long runs for heat and reliability - Got great results
- Not hot at all. 2.5A per LED doesn't generate a lot of heat.
- Great efficiency with the lower drive current + multi LED
- Does require extra low resistance cells such as Samsung 20R for max potential.
- Keeppower 3400mAh for example will draw around 5.2A for around 2200 LED Lumen.
- Dedome throws nicely with a nice focused hot spot
- Dome yield the most lumen for a more floody beam
- Free 18650 Sleeve
Options:
A) Dome 6500K $130
B) Dedome 6500K $140
C) Dome 4500-5000K $145
D) Dedome 4500-5000K $150
Special Request Single Mode Direct Drive of any LED options above is also available
+$5 for "V54" hand engraved body
+$15 if you are outside of USA
+$30 to Option B) for XML2 PDTn, PDTw or U3 PDTc
Email/Paypal: [email protected]
- Free 18650 Sleeve
Options:
A) Dome 6500K $130
