Icanseeyou
- Joined
- Feb 27, 2015
- Messages
- 10
Hey all, I've had this NightHunter One lying around for years now. When I first got it used, it would work both on and off the charger. Worked perfect. Then I unhooked the charger to take it out one night fully charged, click click. No light. Put it back on the charger, it worked. Let it charge again, still no light off the charger. So I figured, ok, the battery has lived its life. I bought a replacement battery. Put it in, let it charge fully. Works still plugged into the charger, took it off the charger figuring good to go. Click click. No light. So the switch is working, bulb burns when on the charger. I've even tried it plugged in sans battery, worked. The guts are still in it and from what I can see, there isn't evidence of arcing, blown/swollen caps, blown resistors, etc.
Any words of warning or helpful advice while taking the plunge? IE, "whatever you do, under any circumstance don't...." etc.:thinking:
