XP18-B (Cree XPG High CRI LED) or XPG2 Help...
neutralwhite
London Heathrow
looking for the same, but in 4000K.
..are these available in 4000K rather than 3000K?, & is the newer XPG2 available in 4000k HCRI?. if so, would the CRI be the same?.
HCRI im looking for in a warm whiter LED. Torn Between 3000 & 4000 really.
I thought Nichia 219 had the highest CRI, but seems XPG is over 90 too.
this was taken from prometheus light's site, as im looking to buy a bespoke from Jason.
thanks,
The Cree XPG High CRI (Color Rendering Index) is specifically designed to deliver accurate color rendering to the human visual system. On a scale of 1-100 it scores a 93+. The LED tint is warm, like an incandescent light bulb, and comes in a CCT (Correlated Color Temperature) of 3000K.
Unlike the more powerful cousins, the XP18-B uses a 1.4 Amp (vs. 2.8A) driver that provides double the run-time and can be operated indefinitely without concern for excessive heat build up.
Why wouldn't you just contact Jason? He is the one who will know what he can put in your light or not.
I see very similar questions from you over and over; you would be best served by an email to Jason. He is very helpful and can tell you if he is able to do what you want.
